955 12A3133 WHAT YEAR? also steering clutch
Thank you received: 7
16 years 4 months ago #18884
by BOWTIEIH
Where can I find information on how to repair steering clutch. I have search the net for service manuals but am not sure which one of these books I need, I really don't want to buy all the books to start with.
Traxcavator 955 Early (12A1) Traxcavator Portion Only Service Manual, 54 pages
Also Need Traxcavator 955 Early Chassis Only Service Manual, 170 pages
Also Needs Traxcavator 955 Early Engine Only Service Manual, 302 pages
Traxcavator 955 (12A1-12A8418) Parts Manual, 368 pages "I have this one"
Traxcavator 955 (12A1) Operators Manual, 110 pages
I got this unit after it had been setting for 15 years. It had a over heating issue when it was parked, they had replaced the radiator and water pump but it steal was overheating on them. After playing around with it I found the issue. no gasket in the radiator cap. Now if I can just get it to turn right, without backing up. The old girl is itching to turn some dirt.
Thanks for any help
Thank you received: 820
16 years 4 months ago #18885
Model year is 1957.
Steering clutch service/repair is the same as the D4 tractor once you get access.
Thank you received: 80
16 years 4 months ago #18895
by gemdozer
for reparing the stering cluch you need to take off the fuel tank and the big housing cover and removed the 2 stering cluch with the bevel gear.
16 years 4 months ago #18896
Working on the steering clutches is not a problem, plenty of discussion, websites with pictures and I can post set up procedures from the D4 service manual.
Problem is there does not appear to be a service manual dedicated to the 955 loader.....you have to use a combination of the loader parts manual and D4 service and parts manual and there is a lot left out.....like how to get access to the clutches without removing the loader frame etc.
An old post said it could be done by removing everything off the deck and slipping the cover out from underneath the frame but I have never seen it done nor do I know if it can be done that way for sure.
