Weekend mechanical puzzler
Thank you received: 10
15 years 10 months ago #18830
by ccjersey
Here's a puzzle.
What is it? What does it mean? What caused it? How did that happen?
Why do these things always happen at 4:30 on Friday afternoon?
Have fun
Thank you received: 737
15 years 10 months ago #18836
Not much to go on:rolleyes:
Looks like corner of exhaust manifold on the left but I don't recognize the casting on the right but I'd guess a head gasket problem and probably on a D330 or D333 which are famous for warped/cracked heads. Am I close;)
15 years 10 months ago #18837
by ccjersey
That green isn't dried creek scum, it's really green. This one has more drama than just a blown gasket.
15 years 10 months ago #18840
by ronm
John Deere 4020 or 3020? or 4430? Looks like she pooped out the head gasket, I've been around JD engines for 35 years, never seen one do that...
15 years 10 months ago #18843
by ccjersey
the next fact in the trail is that at exactly 180* on the crankshaft markings it has a hard spot as you turn it over by hand. (JD 404 6 cylinder in a 4020 -firing order 153624 I believe)
Ron ID's it in 1!
Tractor has been running for years around the farm and I believe the engine is a reman shortblock, but I can't remember for sure. Anyway it was running fine, pulling silage wagons late Friday afternoon.
Remember, I'm not telling the obvious, yet.
And Ron, the reason you and I haven't ever seen one do that is..............?
Thank you received: 6
15 years 10 months ago #18848
by ol Grump
I"m wondering if a coolant leak developed internally and the engine was shut down for a while. Then when it was restarted, a hydraulic lock happened in one cylinder and pushed the head gasket and twisted the crankshaft all at the same time? Just a question. . .
15 years 10 months ago #18849
by SJ
The D318 engine which was used esp. in the 8U & 9U D6s had a habit of seeping along the outside of the head so I never put one together without coating the gasket along that outside edge with #2 permatex and it took care of it. I also put a thin coat on one side of the gasket all over it to help with leakage which could occur down the road whch they did at times.
15 years 10 months ago #18854
by ccjersey
Ol Grump, you're gettin there, just keep thinking along those lines, but no, the engine was running at the time.
That's a major factor in this.
Thank you received: 14
