D6 9U 3405 Dry Clutch Adjustment?
16 years 4 months ago #18794 by First Cat
I tried to adjust the clutch by losening the adjustment bolt on the clutch and had no luck in moving it. OM said it might be rusted. How can you tell if the clutch is fully adjusted? If it is rusted how is the best way to free it.
16 years 4 months ago #18796 by Old Magnet
By fully adjusted do you mean the limit of the adjustment????......when the adjustable collar bottoms out on the hub....there is no more.
Usual method of soak, beat, pry and as a last resort heat (don't set the place on fire;) ;) ) to get the collar to break loose.
If you suspect it is bottomed out try rotating in opposite direction to get it loose.
16 years 4 months ago #18802 by First Cat
Yes , the limit of adjustment is what I was asking about. Thanks I'll see what I can do.
Time to create page: 0.131 seconds
