cat 22
16 years 5 months ago #17930 by volvo guy
cat 22 was created by volvo guy
i have a cat 22 with a steering clutch problem thare is no left hand steering working at all.anyone can tell me how to put a new steering clutch in also where to get the parts required.i am located in UK England and i very much like reading all your comments most helpful.keep up the very good work.volvo guy.
16 years 5 months ago #17932 by Catmatt
Replied by Catmatt on topic cat 22
Volvo Guy-
I am assuming the tractor drives but doesn't turn. If that is the case, the clutches are stuck together. If the one side doesn't drive, the pinion has probably been sheared.
POur kerosine/diesel into the clutch compartment and drive the machine around to stir everything up. Tie the handles back and let it soak for days/weeks. If that doesn't work, try pulling a heavy load, will hold the handle back, in an effort to break the clutch free. If that doesn't work, it is time to get the wrenches out...
Break the track.
Remove fender, Track Frame (Crib motor up). Remove brake linkages, and bolts hold final drive to tranny case. Pull final drive off. Now you have to remove the retaining bolts and oiler on the yoke, and also the linkages attached to the steering cluch handle. Remove the nut/lock washer holding clutch to shaft. Get a bar puller, possibly heat, and a hammer to remove the clutch. Use an engine valve spring compression tool to remove the clutch pack. When you get to this point, post again for thickness specs, etc. Also, make sure you replace the Thrust bearing!!!!!!!!!! (hopefully i didn't miss a step as this was all from memory)Good luck
I may have parts if you need some- <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
16 years 5 months ago #18002 by volvo guy
Replied by volvo guy on topic cat 22
Hi many thanks for your reply it looks very useful information i am sorry i have been so long replying i have been away.i will let you know how i get on in due course many thanks volvo guy
Time to create page: 0.125 seconds
