Pull Start No. 6 shovel ?
16 years 5 months ago #17796 by desoto
I need some advice before I attempt to pull start a No. 6 shovel. I believe the motor is stuck and would like to try and jar it loose by pulling it. It has an oil clutch. My question or concern is will I be able to pull it like you can with a regular clutch ? Thanking anyone in advance for their help . Ed
16 years 5 months ago #17797 by SJ
Replied by SJ on topic Oil Clutch
There is no difference between an oil clutch and dry one except the oil in it and the parts are different to make up for the use in oil and a couple other items so you,ll have no problem.I think if it,s stuck I,d look into why a little more before pulling it.You could try to bar it over if you can get to a place like the pump drive in the front or the flywheel teeth.There should be a small plate on the right of the bell housing in the front side of it so remove it and usually the timing pointer is in there so maybe you could bar it a little from there but be careful of the pointer. If it is stuck you always could take the spray nozzles out and pour some fuel oil or kero. on top the pistons to help loosen them but would take a little time for it to work.Maybe someone has something better to use than the fuel oil or kero.
16 years 5 months ago #17800 by firpitch
Replied by firpitch on topic Pull Start No. 6 shovel ?
I have heard of using DMSO but have never tried it myself for machinery. I do know that it will go into your skin and you can taste it and it works to loosen stiff old joints and hands.
16 years 5 months ago #17801 by d47u
Replied by d47u on topic Pull Start No. 6 shovel ?
I have had good luck using brake fuild to unstick engines.
16 years 5 months ago #17802 by Old Cats
Replied by Old Cats on topic Pull Start No. 6 shovel ?
Be sure your valve are not stuck before you try pulling it or you may have bent pushrods and broken rocker arms. Just go along tapping the valves with a composit hammer or brass hammer. They should drepress and return to their original postion.
Hope you get it going.
Time to create page: 0.146 seconds
