D2 44 Hydraulics
5 years 7 months ago #200513 by rockymnt
D2 44 Hydraulics was created by rockymnt
I am resealing my 1950 D2 Cat 44 single valve hydraulic pump. I need help with finding a redi sleeve for the input shaft, 4F4408, the seal, 5F4721 a double lipped seal, has grooved the shaft in both spots causing a wear groove and thus leaking. Dana at Florin can't just look up a redi sleeve, he needs a number. I have asked Wagoner Cat of Colorado, and they are trying to find something, but has not been able to locate the sleeve, if you have any information please post it for me.
5 years 7 months ago #200514 by STEPHEN
Replied by STEPHEN on topic D2 44 Hydraulics
I don't have that shaft in hand right now, but your local bearing supply should be able to measure and order the sleeve. I know that is not as convenient as just ordering, but that's all I have sitting here. If you can mic the shaft you might be able to look up the correct size online. Or hopefully someone remembers what they used before. CR/SKF speedi-sleeve is what I have used.
5 years 7 months ago #200516 by edb
Replied by edb on topic Speedi-sleeve Listing
as said, if you measure the shaft diameter you can likely select a suitable sleeve from the link list.
So as the seal lip does not burn on the sleeve I suggest you fill the lip wear groove on the shaft with epoxy and machine it true--the air gap between the sleeve and the shaft does not dissipate any heat build up away efficiently--a thick Lock-tite product may work for this as well--could even be something special in their product line by now.
In the first link I believe they have mixed the Inch and Metric size listing dimensions--
www.industrialbearings.com.au/uploads/ca...leeve_1338271826.pdf
www.skf.com/binary/21-318152/810-701_CRS...-SLEEVE_Apr-2018.pdf
Hope this helps.
5 years 7 months ago #200519 by Old Magnet
Replied by Old Magnet on topic D2 44 Hydraulics
Pump shaft is 1-1/4" - 10 spline.
5 years 6 months ago #200526 by rockymnt
Replied by rockymnt on topic D2 44 Hydraulics
Outstanding Gentlemen!! I knew I could get some help thank you most kindly ! I will get on this !
Rocky
5 years 6 months ago #200530 by Old Magnet
Found my notes!!!
Pump shaft takes a #99112 speedy sleeve.
The 5F4721 double seal is replaced by two # 3H1397 seals
3H1397 is equivalent to a skf/cr # 15141 or national/timken #51098
5 years 6 months ago #200538 by rockymnt
WOW, the help you all give just because you are a good person makes you believe !! Thank you all !!
Rocky
5 years 6 months ago #200542 by neil
Replied by neil on topic D2 44 Hydraulics
I put one on my 44 a couple of years ago - works just fine. Used them in a few places including sprocket shafts, steering clutch shafts, and transmission input shaft
5 years 6 months ago #201116 by rockymnt
Om, what make is the speedy sleeve, ir is not an SKF it is the wrong size.
5 years 6 months ago #201120 by Old Magnet
The 99112 is a CR number (Chicago Rawhide). Should be able to cross reference to SKF.
For 1.123" to 1.127" shaft diameter.
