Power Unit
Power Unit
5 years 10 months ago #198787
by JHall
Howdy Folks, I picked a d315 engine the other day and need some help figuring out what year it was built. It had been sitting in a old barn on a dairy farm for quite some time but it was out of the weather. I took a big pipe wrench and a bar to try and roll her over. To my surprise the main broke free and after a full turn was free. The pony freed up by hand but doesn't have much compression if any. The inspection plates on the side of the block we're missing all but two bolts so I figured it has a bottom end problem. So when I got home I pulled the covers and found out why she had been sitting in a barn for thirty years. No2 rod had spun a bearing or something to that effect. It showed signs of heat and had plenty of slop in the bearing. The rest of the rods looked good and had some float in them. The clutch housing is drilled for electric start and I would like to use it on a D4 that I'm working on. Is a power unit housing the same as a 7u dozer housing. Thanks for your answers....Jim.
Thank you received: 824
5 years 10 months ago #198803
Flywheel housing, oil pan and oil pump are not the same as the 7U. Governor arrangement and rack settings will also be different. I'd have to do more digging but I don't believe the front timing gear cover is the same either.
On further check the timing cover is the same.
If your tractor doesn't have the engine balancer the early belly pan will not fit the later engine with balancer. Would require the later belly pan.
5 years 10 months ago #198814
by JHall
Thanks for the info Old Magnet you are always on top of things. Could you possibly give me an idea of what year it was built. The number on the tag is 9S11838. I guess I can use the cutch housing for measurements to cut the hole for starter in the 7u housing. If anyone needs a pan, front support, clutch housing for a D315 power unit let me know as I don't need them and I have to see good parts go to the scrap yard.
5 years 10 months ago #198818
My listing doesn't go to that high a s/n so I'm guessing 1957, 58, or 59.
Use these dimensions to bore your flywheel housing, not sure if the Industrial Housing is the same. I was fooled by a D318 Industrial Housing not being the same as a D6.
5 years 10 months ago #198826
by Chuck C
Bell housing is different power unit to d4 dozer. A friend of mine is doing the same swap.
Chuck C
5 years 10 months ago #198832
Maybe I wasn't clear. The housings are obviously different but it's the starter hole location dimensions that I was referring to.
Thank you received: 60
5 years 10 months ago #198839
by hfdzl
Set up 2 rows of letters and numbers as so
N U M E R A L C O D
0 1 2 3 4 5 6 7 8 9
I can't get the spacing just right but you get the idea. The main pieces, the engine block, oil pan flywheel housing and possibly others will have a 5 or 6 digit letter code. That will transfer to the number chart. This is the casting date, and will be within a few months of later assembly. May have to wire brush or clean heavily to see. Still works today as far as I know.
Good luck,
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Power Unit
Time to create page: 0.188 seconds
