D13000
D13000
16 years 6 months ago #17181
by charles poole
Ol magnet , The fuel rack on my 2U engine is locked up due to to water intrusion,Do you think it would be possible for me to switch housings,injection pumps and all from my 4S to the 2U ? I would like to do this to retain the rack settings of the 4S , also I need to switch the fly wheel from the 4S to the 2U as the 2U flywheel doesnt have the same number of bolt holes for the clutch assembly , Last but not least what do I need to know about the timing marks for the Flywheel and injection pump timing ??
Regards ,
Charles poole
Thank you received: 820
16 years 6 months ago #17186
Hi Charles,
Yes, the fuel injection housing/assembly will interchange as a whole unit. Timing is by offset drive tang and slot.
Set the engine up to #1 firing position and pump lifter position and also so you can check flywheel timing. There should be assembly marks on the crankshaft flange and the flywheel but it pays to check when interchanging. Check that the timing mark on the perimeter of the flywheel is visible through the cover plate window on top of the bell housing. If all is right when #1 piston is in firing position, injector pump lifter is at or near top of stroke, flywheel mark is under the timing pointer and flywheel marks all line up.
They did use several different flywheel drillings for the twin disc clutch, the rockford clutch and the open style dry clutch. As far as I know the crankshaft mounting flanges were all the same.
D13000
Time to create page: 0.131 seconds
