Help! Need info on sulphur substitute. non ATF
16 years 6 months ago #16960
by denjoe
So much stuff on the LOW SULPHUR consequences with pump and injectors. I have a D64R that I am now afraid to put fuel in. I had heard that ATF would work but the guys at the machine shop say No! It causes coking. "Gunk" has something they say on the label is a sub. Any thoughts? I also saw a posting about adding CANOLA oil @ 1 percent. ???????
16 years 6 months ago #16964
by drujinin
by using ATF, Canola Oil or BioDiesel. My thought would be Marvel Mystery Oil because it is advertised as a top end lubricant.
Any of these would probably (maybe) cause coking. I do particially agree that ATF isn't the best option as it has alot of other chemicals in it.
Some guys even pour there drain oil into the diesel fuel.
Thank you received: 47
16 years 6 months ago #16969
by 8C 361
2 stroke oil has been recommended. Wal*Mart has it for about $7 per gallon. I am also running Non-Detergent 30W at about 1 qt per 10 gallons of fuel.
Tom
16 years 6 months ago #17009
by Roland
hi we have had the low sulphur diesel here in the uk for a few years now and Im not aware it has caused much in the way of problems I do however remember it seemed to cause some pumps to leak think it afected nipon denso on small car and light trucks toyota and mitsubisi etc I would guess your refinerys will have used the same aditives for lubricty etc that we get in our diesel so you should be good to go.. hope this helps
Time to create page: 0.153 seconds
