D4600 piston erosion
6 years 4 months ago #191018 by eric jensen
When I was changing the pre chamber i noticed some erosion on the top of the cylinder 3/16 or a little more this motor might get 20 hours a year on it what do you guys think
6 years 4 months ago #191019 by WA7OPY
Replied by WA7OPY on topic D4600 piston erosion
Run it till it fails, at 20 hr year it will out live you.....WA7OPY
6 years 4 months ago #191023 by Rome K/G
Replied by Rome K/G on topic D4600 piston erosion
"now when your tractor runs like crap like this one, that's whats going on in there"
6 years 4 months ago #191038 by oldbeek
Replied by oldbeek on topic D4600 piston erosion
I would change that nozzle.That cut looks like centralized spray from a bad nozzle.
6 years 4 months ago #191039 by Rome K/G
"ya got that right!"
6 years 4 months ago #191051 by eric jensen
Replied by eric jensen on topic D4600 piston erosion
Can you still get reman injectors for it I have a nozzle tester can you buy parts for the inside I am looking for the part number for the copper under the injector hold down
6 years 4 months ago #191098 by oldbeek
the tip in the parts book is called a cap 2A5746 it doesn't show up on machinery trader search part . The valve shown as 7B8089, don't know if this includes the tip, 302 at Florin tractor in Sacramento CA. Only gasket shown just below a nut 2A5744 Florin has 77 of them. You have a test bench?? just check out the spray pattern. I shoot them at a piece of cardboard to see how they spray. I have a 9K3585 cat 12 that I am parting out if you ever need something. The engine is seized and I have not got into into see if there are any good parts.
6 years 4 months ago #191108 by eric jensen
Yes I have one of the hand pump testers I just half to see if it has the right adapter I just don't want to make the piston worse
6 years 4 months ago #191136 by oldbeek
Should have evenly spaced spray pattern. Each pattern should be the same, size and volume.
6 years 4 months ago #191214 by eric jensen
Here are some pictures of the injector being tested it looks OK to me i think they we done awhile ago but i wouldn't have seen the piston untill the pre chamber broke
