Model 41 hydraulic unit part numbers
16 years 6 months ago #16785 by Chuck C
I am going through the 2 valve 41 unit that I bought . I need the part numbers for the bushings that the control rods enter the unit. The unit has needle bearings in it but the seviceman reference book shows bushings. I have a sheet that the Cat parts guy gave me but the bushing are not shown. I need 4 bushings,4 seals, 2 retaining rings, the imput shaft seal, the big gasket and a filler cap. The serial number is 24C688 but it must of had a second valve added at some time. If anybody has a parts book for sale or a good copy I would be interested.
Thanks in advance.
Chuck Czaplewski
847-459-3381
16 years 6 months ago #16788 by Old Magnet
Early versions used bushings pt # 1H327 and seal # 1H326
Later versions used bearings pt # 3H5076 and seal # 3H5077
16 years 6 months ago #16793 by Chuck C
Thanks OM. How do I tell the difference?
Chuck C
16 years 6 months ago #16794 by Old Magnet
You need a parts book and the serial number to tell.
Actually I am referencing the 28C1, 29C1,30C1 (rear mount units) as I don't seem to have the front mount units manual but I'm pretty sure they followed the same sequence of part changes.
16 years 6 months ago #16796 by Chuck C
Thanks OM, the serial number is 24C688
Chuck C
16 years 6 months ago #16805 by josh
Chuck,
Your #41 will use the later parts OM listed,
The ring that goes with the lever is 2h4146,
Input shaft seal 1b2346
Big gasket 1h0566
filler cap 1h9588 and gasket 1h9589
16 years 6 months ago #16806 by Chuck C
Thanks Josh
16 years 6 months ago #17098 by Chuck C
I would like some pump info. The numbers on the pump are V-200-11-19D-12, 26 (all by itself) and S-19lh. Can anybody tell me the capacity of this pump? GPMs?
Thanks in advance
Chuck C
16 years 6 months ago #17105 by Old Magnet
Those are Vickers parts numbers......might try giving a Vickers pump dealer a try.
