Leaking Gasoline Valve
16 years 9 months ago #16431 by C.J._archive1
The gas valve that turns the gas off from the tanks leak where the stem comes out of the valve by the packing nut.Valve part number 3640-A, I tried tightening the packing nut but that doesn't do it. Is there suppose to be some king of packing material around the stem for a seal? Or what do I have to do to get it to stop leaking?
16 years 9 months ago #16448 by naylorbros
Replied by naylorbros on topic Leaking Gasoline Valve
There is packing under the packing nut. I have repacked them with water pump packing, but I have had to keep tightening them to keep them from leaking. If any one have a good packing to work with gas please let us know.
Ken
16 years 9 months ago #16467 by DLF_IN
Replied by DLF_IN on topic Leaking Gasoline Valve
Hello,
If you can, check with a outboard shop that repairs some of the older Johnson or Evinrude outboard engines. The carb needles used packing on them. I know that gasoline will not affect them. I think that these packing washers would work on the shutoff valves.
Dave
16 years 9 months ago #16468 by D6 Pete
Replied by D6 Pete on topic Fuel leak
I have used hemp string in the past, and it worked fine!. Regards, Peter
16 years 9 months ago #16471 by C.J._archive1
Thanks for the replies I will see what I can find for a packing material.
