pinion shaft removal
16 years 9 months ago #16404 by chriscokid
are there any tricks to getting a pinion shaft out of a d-2 3j series.
16 years 9 months ago #16461 by chriscokid
Replied by chriscokid on topic pinion shaft removal
i have seen someone heat the housing with a tourch to remove a shaft, and they put the shaft in a deep freeze for a couple days before they installed it, does anyone else have a better idea. I am not to keen on heating a cast housing!
The shaft I am talking about is the pivot shaft that the track rails work off of, mine is bent on one side.
16 years 9 months ago #16462 by drujinin
Replied by drujinin on topic I thought.....
that is bolted to the chassis? I haven't studied the underneath in great detail yet.
16 years 9 months ago #16473 by Sasquatch
Replied by Sasquatch on topic pinion shaft removal
Once the track frames are off the shaft there are two caps that bolt to the bottom of the tractor that hold the shaft on. Each cap has four nuts holding it on. One cap should have a big dowel under it that also goes into the shaft to keep the shaft postioned. Once the caps are removed the shaft should come out. A couple I have had to tap with a hammer to remove from the bottom of the tractor but it usually doesn't take much.
Time to create page: 0.146 seconds
