help needed with winch on d8h
Showing 1 to 10 of 10 results
springhillrookie
Send a private message to springhillrookie
I have a d8h s/n 46A 1646. It has a cable blade, blade or winch have no plates or casting to identify who the manufacturer is.
The winch clutch is slipping I need parts for winch but I first need to figure out what brand it is.
Winch is a two spool winch with spools sticking out back instead of cross ways. The winch cover has a half-moon slot in it at the back.
Can anyone help me with this?
Fri, Apr 25, 2008 12:54 AM
tenncat
Send a private message to tenncat
If one drum is used for the blade, a better description of this would be a cable control unit. If so, there really isn't but one of these that would be mounted on this D8. Consider taking a picture and showing it to someone in the parts department at Thompson Machinery in Columbus 662 327-3083 or Greenwood 662 453-5233. Make sure and bring the tractor serial number, they've always been helpful to me. Good luck.
Fri, Apr 25, 2008 1:09 AM
It'll be a CAT winch and on an older tractor I would say it surely would be a #25, but could certainly be a newer model and you will need a serial number anyway to be certain to get the right parts.
When you say the clutch is slipping, will it raise the dozer if you pull hard enough on the lever? Or does the dozer fall when you release the lever?
adjusting will help both problems.
Look at this thread
http://www.acmoc.org/ACMOC_BB/showthread.php?t=3267&highlight=adjust+cable
Fri, Apr 25, 2008 1:25 AM
Thank you received: 39
Look at this thread
If the drums are sticking out the back that would be a #128 ccu serial number 18F1-up (double drum)
The serial number tag should be near the top of the right hand drum housing.
Fri, Apr 25, 2008 2:45 AM
springhillrookie
Thanks for the help, I have taken pictures of this cable control unit.
And tried to upload them.
Fri, Apr 25, 2008 8:04 PM
springhillrookie
Reply to springhillrookie:
How do I post pictures to this?
Sorry but I have not had any luck.
Thanks.
Sat, Apr 26, 2008 4:48 AM
Thanks.
Send me a private message with your email address.
I have the Operations and Parts Manual for the #128 ccu.
The regular email is required to send attachments.
Sat, Apr 26, 2008 5:04 AM
catsilver
Thanks.
That will be a 128/129 cable control, the early ones had hydraulically boosted controls, recognised by a hydraulic pup and pipes on the top right side, Most were converted to manual control. If you can post a picture we can confirm what it is and I may still have the adjustmnet procedures in an old service magazine. Just be warned, don't even try and make any adjustments with the engine running, these things bite the unwary.
Sat, Apr 26, 2008 5:05 AM
Reply to catsilver:
Hi catsilver,
We have the model defined and yes it is manual control
I forwarded the adjustment procedures but they are for the hydraulic assist units.
Question is.......are the adjustment procedures any different for the manual units?
Mon, Apr 28, 2008 11:57 AM
springhillrookie
Hi catsilver,
Thanks old magnet for all of your help.
Thanks to everyone for helping me with this cable control unit.
The adjustment procedures are very similar which allowed me to figure out what to do. Again, thanks for your help!
Tue, Apr 29, 2008 8:32 PM
catsilver
Hi SJ,
There isn't much difference in the procedures apart from the early brake spring tensioner was a chain! I will scan in and post my old product bulletin overr the next couple of days for future reference.
Wed, Apr 30, 2008 4:21 AM
