Serial number help please
Thank you received: 193
6 years 10 months ago #182541
by josh
The one I have was the twin to yours, Same pump, and electrical, but by the time I got it the generator, starter and battery box had been taken, just the brackets left. on mine the undercarrage is near new, everything functions well, but the engine is tired, it starts and runs ok but there is so much unburnt fuel, it's just unpleasant to run, I think it's just low compression.
Thank you received: 345
6 years 10 months ago #182565
by edb
Service Magazine scans below should answer this query.
SP, Special Parts. SPC-G Special Gearing.
Thank you received: 825
6 years 10 months ago #182570
That appears to be an old designation using SPC-G. I was under the impression that later versions just used the designation SP that might indicate different gearing and even later a separate tag was added for gear designations. What does the "C" stand for?
Thank you received: 5
6 years 10 months ago #182577
by terrywelch_archive
I have a R5 did not know which way to hook the battery. So I went to my expert and he told negative ground on all these machines.
Terry
Thank you received: 881
6 years 10 months ago #182584
by juiceman
Thanks everyone. I am baffled though, if grounded wrong I would suspect either damage to starter motor or possibly reverse rotation? I have always used negative as a ground, with the exception of my Minneapolis Moline tractor.....
Thank you received: 84
6 years 10 months ago #182587
by mog5858
very interesting i know My Euclid is also positive ground. with them i think it had to do with the application. as them D.D motors where made like Lego with more than one mounting place so as to get the right rotation of the starter. if it dose have different gearing that could be why it seemed to have more H.P. i think OIH had a D2 with different gearing too i can't remember if it was faster or slower.
6 years 10 months ago #182594
by juiceman
Starter motor doesn't care what the polarity is.
Thanks! OMag!!! I will swap back to -ground!!!
Thank you received: 957
6 years 9 months ago #182610
by Deas Plant.
Hi, Old Magnet.
Please correct me if I am wrong. My understanding is that the ground to the body/frame of the machine is simply to eliminate the need for wires coming to the 'ground' terminal on the battery from every individual electrical item.
I have been led to believe that the current still flows positive to negative, no matter which way it is 'grounded'. If the positive terminal is 'grounded', it only means that the whole unit is 'alive' and the switch for each electrical item simply opens the circuit on that item for the electricity to flow back to the battery, thus activating that item.
Or have I been led astray all these years?
A kew-ree-yuss mind would like to know.
Time to create page: 0.218 seconds
