D2 Tool Bar Dozer
16 years 9 months ago #16115 by compressor
D2 Tool Bar Dozer was created by compressor
Just aquired new d2 with tool bar dozer. My problem is some of the pins are a little loose.What would be the best way to repair these.
I thought maybe welding and redrilling or? Any ideas would be appreciated.
Also,why are these so narrow compared to an 2A blade.Wonder how hard it would be to extend the blade 6" or so on each side.Any thoughts?
THANKS IN ADVANCE COMPRESSOR
16 years 9 months ago #16117 by ccjersey
Replied by ccjersey on topic D2 Tool Bar Dozer
The angle blade has to be wider so it will still be wider than the C frame when it's angled. The straight dozers are just wide enough to keep the push arms from rubbing the side of the cut (and they still do anyway).
16 years 9 months ago #16124 by ag-mike
Replied by ag-mike on topic D2 Tool Bar Dozer
tb hardware not hd as angle or straight blade tractors. made for rear tb work. i'd keep original.
16 years 9 months ago #16125 by side-seat
Replied by side-seat on topic D2 Tool Bar Dozer
I rebored my toolbar blade pin holes oversized to make round again. Then I made new pins to fit them. Good thing the D2 toolbar blade isn't very heavy because I just clamped it onto the table of my horizontal milling machine and supported the other end with the forklift to do the boring. I did the side arms ends and diagonal boss the same way.I guess the easier way is a portable boring bar if you have one.
16 years 9 months ago #16129 by cr
Replied by cr on topic D2 Tool Bar Dozer
I have bored them out on a bridgeport mill by swinging the head so it was located just at the end of the table, then I put the push arms onto the machine and clamped them down. The main thing is to get the load balanced onto the table.
Time to create page: 0.299 seconds
