Cat 22 Clutch Info
Cat 22 Clutch Info
16 years 7 months ago #15976
by powergiant
Working on a 1936 2f.
This machine is new to me and the clutch adj was at full length.
Have it apart (at the flywheel) and need clutch lining thickness spec.
Also the "brake flange assembly" part V407 has lining gone, thickness spec for that is also needed, part V-129. This part seems to act as a throwout or thrust for the clutch fork.
The clutch steel disk is loose from the hub that rides the shaft. Holes look ovaled out and there is wear from being loose. Can this be redrilled with larger hardware? No cracks on either section. Is this a common problem? Any good used ones out there? I presume new is non existant. Any cross replacement?
I notice the later models have a cast "brake flange assly" that seems a bit tougher does it interchange?
Cat 22 Clutch Info
Time to create page: 0.232 seconds
