- Thank you received: 0
That's a Cat CCU if my eyesight is true, maybe a 23 or 25. Uncle August, on tractors where the brake drum also contains the steering clutch pack, sometimes the clutch can be freed by riding the brake on that side until it's hot (meaning smoke pouring out of it HOT) with the clutch lever held back, and applying a heavy load, like you'd get from dropping that scraper bowl into the dirt a few times. I'm not familiar with how the steering and brakes are set up on your tractor so this technique may not apply.
If it does and it works, it can save disassembly etc.
That’s great!! Looks like a farm cat with a ccu on the back? Or is it a bee Gee hydraulic unit? At any rate if you can hook it up to something that will load it good ( like that scraper) you might get lucky and get the clutch to release. I’ve heard of driving around with the brake applied slightly to make some heat helps.
Are you by chance located in the PNW??
Good luck
BP.
Hello Neil,
Thanks for the hot brake suggestion, and that is the way this tractor is set up. I will try adding that to the mix. Last time I ran the tractor, I was making all left turns, pulling the right clutch a lot, and trying to work the tractor hard, but I never used the brake as a heat generator. I would (reluctantly) say that I was operating abusively, in hopes of avoiding disassembly, but not excessively heating up the brake in the process.
I find it interesting that an IT consultant in New York would recognize a Caterpillar 25 CCU, refer to the "scraper bowl" AND have an idea on freeing a stuck steering clutch! I can only think of about one (almost old) person within 50 miles of my rural Eastern Washington farming community who might be able to duplicate that. Is there farming or construction in your background? It's a little muddy out there for scraper operation right now, but I might try something along those lines before resorting to disassembly.
Thanks again!
I was able to start the engine today, after several hours of effort over a few days. Would like to post video of it running, but haven't figured out how to do that.
Now I have the stuck steering clutch to deal with. I suppose that will require removal and disassembly. Any suggestions to try first?
Thanks for your help so far, and for any new suggestions.
support@acmoc.org
- Chris R
- Jason N
