cat 22 mag
cat 22 mag
16 years 10 months ago #15488
by fstelma
i just got my 22 home and am i need of some pointers, cap is cracked for the mag, are there replacements avab.? and the fireing order, also where #1 would be on the cap, im new to these older ones any help would be great, thanks!
16 years 10 months ago #15504
by fstelma
Ok, Im 99.9 Sure The Mag Is Shot, Its A Model Ct-4 Ser# J7435, Eisemann. Any Interchanges THAT WOULD REPLACE THIS???
Thank you received: 5
16 years 10 months ago #15508
by Old Cats
Most any of the Fairbanks Morse J series will fit as will other Eisemann and most other mags as long as the rotation is the same. Rotation can be changed but it takes some work on the impulse and changing the timing of the mag internally. Most mags are marked for number 1 but it really makes no differance as long as you make sure which post is firing on the mag and connect that to the cylinder that is also in the firing position. If I remember the firing order is 1-3-4-2 but best check that out for sure. What I do is fire the mag, get the cylinder at TDC for the firing stroke and attach the mag without moving anything, then fine tune from there.Good LuckGene
16 years 10 months ago #15592
by WyoCat
The correct mag is actually or should be a CM-4. I have a good hot one for sale. If you are interested, please feel free to PM me.
Chad Enyeart
cat 22 mag
