only place I believe
16 years 10 months ago #15401 by firekat
only place I believe was created by firekat
Well
I'm redoing a pup motor for a 8R, need rod bearings:o . I can find Mains through RegalCorp. I have searched all bearing sources for pup motors even jd sources have come up empty except for :eek: Cat :eek: is this the only place you can get rod bearings now? I would like some input. I'm thinking of getting new rods made and grinding the crank down to the next nomial size bearings that I could find easy. any sugg.
thanks
firecat
16 years 10 months ago #15451 by Jack
Replied by Jack on topic only place I believe
Look into having them babbitted. When I was hunting undersize bearings I came up with three shops that do it. Pony motors don't run all that much. Babbits are a lot better than they used to be. Any shop with a rod reconditioning hone can make them fit.
Try GAFFREY BABBITTING in N. Dakota 701-225-5482
or PAUL'S ROD AND BEARING in Missouri 816-587-4747 talk to Russ. (Probably best bet)
or VINTAGE ENGINE MACHINE WORKS in Spokane, WA 509-999-2119
Good luck.
Jack
Time to create page: 0.119 seconds
