RD4 Caterpillar project
16 years 10 months ago #15321 by R4pat
I've been currently working on this RD4 fixing leaks, working the starting pinion over. After putting a new thermostat, and cleaning the water jacket of the pony engine, I've finally been able to start without starting fluid:) it did take 15 minutes to get the block hot enough, hopefully after a little work out it will get better. Right now I am wondering if someone can help me with some part #s for this oil filter which is not in my parts manual, alls I need is the #s for the filters, O Rings and the gasket or the copper ring that goes under the bolt head on top.
soon I will be going into the rear end, making popping noises when :confused: , hopefully not bearings, and one of the stearing clutches slips
Thanks for any help or information
16 years 10 months ago #15330 by Haole Cat
Replied by Haole Cat on topic D-4
Looks like a fun project. Judging by the photos, you a few nice projects.
16 years 10 months ago #15332 by gwhdiesel75
Replied by gwhdiesel75 on topic RD4 Caterpillar project
Glad to see another RD4 saved and running.
16 years 10 months ago #15334 by ol Grump
Replied by ol Grump on topic RD4 Caterpillar project
Can't help ya with the filter but for o rings and copper gasket you might try a good automotive parts house or hydraulic shop.
16 years 10 months ago #15341 by Old Magnet
Replied by Old Magnet on topic RD4 Caterpillar project
Lower can gaskets 5B5973 (2)
Upper can gasket 5B5937 (1)
Bolt gasket 5B8927 (1)
Upper element 5B8934
Lower element
(inner) 5B5983
(outer) 5B5984
16 years 10 months ago #15364 by dewets
Replied by dewets on topic RD4 Caterpillar project
Someone's bin busy widda cleaning process!
That shed's got quite a few yeller pieces about it!
Great. :) :)
Somerset West, Cape Town
South Africa
16 years 10 months ago #15367 by ccjersey
Replied by ccjersey on topic RD4 Caterpillar project
That has to be one of the first oil filters fitted, never saw one like that before.:D
16 years 10 months ago #15388 by cr
Replied by cr on topic RD4 Caterpillar project
A lot of the early D4's and D2's had that filter. I have a few old old cats like that in the pile.
16 years 10 months ago #15390 by R4pat
Replied by R4pat on topic RD4 Caterpillar project
We have another RD4 real close in serial # to this one with the same filter
16 years 10 months ago #15471 by R4pat
Replied by R4pat on topic Bad News
This week I decided to take a look at the rear end to find the noise I've been hearing, well, take look close look at the final drive gear in the picture, two teeth missing, and thats not all, one of the locks for the shifting forks was dangling, because the bolt and spring that holds it up broke, what kept it from getting messed up worse, I don't know, This broke gear is a straight tooth and a D4 has a curved to tooth, will both the gears interchange? probably going to have to replace the drive gear that runs this one also so the gears don't bind up. I'll be looking for gears if anyone knows of any
