D2 Engine
D2 Engine
16 years 8 months ago #15139
by 2bluejon
I was wondering if some one could help me i am not getting any fuel to the motor i can give it a spray of eather and it will cough like it wants to run so i know i am not getting any fuel. I put some air pressure on the fuel tank and still nothing this is my first can and i am not sure i know what i am doing thnks Vern
16 years 8 months ago #15142
by SJ
This is a seek and find job so first take the main fuel line from the tank to the transfer pump under the filter and see if you got fuel coming there.If you do have fuel then remove that block that the line screws into and clean the spring and plunger inside the block and then proceed to bleed the system out from there. Could even have the rack stuck inside the injection housing so just take the side cover off it below the fuel pumps & lines and check there if it moves when the throttle is pulled on.This is a few things to check first to maybe find the problem.
16 years 8 months ago #15175
by 2bluejon
When i put the air pressure on the fuel tank i can get allot of fuel out of the 1st and the 3rd fuel pump hole and a little out of the other two not enuf to do any thing i was planning on pulling of the plate on the side of the injection pump and looking and seeing if i could tell anything let me know if you have any other ideas thanks Vern
16 years 8 months ago #15178
by SJ
When you get the side plate off the inj. housing see if the pumps are all raising and lowering ok as those two that show little fuel could be stuck esp. if the tractor has been setting for a long period of time.If they are stuck it might be a good idea to change the filters any way if they,re not and clean out the filter base and if the fuel is old in the main fuel tank then install fresh new fuel in it.
16 years 8 months ago #15192
by welovecomics
I hate to admit my first adventure with starting a D2. The throttle has some travel after it goes past the fuel shutoff detent. This means you can move the throttle up and down and still be in the shutoff mode. Make sure it "clicks" past the detent into the operating range before throwing in the compression release. Good Luck!
16 years 8 months ago #15194
by 2bluejon
I got the old thing running and it purrs like a good cat thanks for all the help you all have helped me with Vern
Thank you received: 405
16 years 8 months ago #15197
by D4Jim
Vern, what did you find was the problem? Just curious as to the culprit!!
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
16 years 8 months ago #15204
by 2bluejon
hey i was looking and the fuel rack was stuck so i pried on the top a little and put some lube on the plunger and they freeed up and run great
D2 Engine
Time to create page: 0.161 seconds
