d8h blade cylinder pivot joints
7 years 1 month ago #168759
by ncfarm
this is a pic of the lift cylinder upper pivot. is there a bushing that will take up all the slack in the pin joint area? i know there is what looks like a wear bushing already there but it sure is sloopy. will i have to weld up the pins on the support members? thanks
Thank you received: 801
7 years 1 month ago #168769
by Casey Root
For the D6C of the 1960s vintage, Cat used a crankshaft or connecting rod bearing insert for that purpose. That is what I used in my "6" after we had to build the ram ears back to a standard size.
Thank you received: 999
7 years 1 month ago #168780
by Rome K/G
Funny how they never see that grease fitting and let things just wear out. Oh well, like the old Caterpillar film "It's Up To You"
7 years 1 month ago #168794
by Rome K/G
That cylinder trunnion is shot! it wont hold a new bearing. The thick bearing is supposed to be pressed or shrunk on.
7 years 1 month ago #168806
by ncfarm
is there a spec measurement for the yoke i need to get back too? part number for the bearings? my part book doesnt cover it.
old magnet where is the serial plate for the blade? i know the machine serial is readable. will that help, also have some more pics of the whole machine just not at my home pc rt now, sorry
many thanks Ty
7 years 1 month ago #168809
Usual place for the s/n is the right hand upper rear side of the mold board. If no tag look for rivet holes and scratch around in the paint. Number is often stamped there.
Most likely a 28Exxxx straight blade or 29Exxxx angle blade. Early cylinders did not have bushings on the cylinder trunion, later ones did.
Yoke bearings are a 3J2217 (8 required)
Yoke bearings were only used in early cylinders so it looks like your lift cylinder trunions do not have the later bearings.
Thank you received: 33
7 years 1 month ago #168813
by bluox
I think that bearing that is missing is a 5J 1192, in classic parts a 374-8355.
Bob
7 years 1 month ago #168825
My parts book shows a 3J2189 lift cylinder in type 1, 2, 3, and 4 without trunion bearings before you get to a 5J1243 lift cylinder with the 5J1192 trunion bearings.
