restoring 1952 D82U dozer
16 years 8 months ago #14907 by 560 farmall
what is the best steel to use to bulid a new cutting edge for a dirt blade
16 years 8 months ago #14917 by jaker65
Replied by jaker65 on topic restoring 1952 D82U dozer
from my experience with applying new cutting edges to a blade or bucket, i have always used AR 50 steel. the armor plated steel lasts a really long time, but could be difficult to work with if you have drill holes. it took me 3 days to drill 8 holes for teeth on a excavator bucket, that i was using armor plated steel on.
if you are only using your dozer 30% of the time and the rest of the time it is sitting, you could get away with 4140 steel. if you go mild steel, you would be wasting time in my book. that stuff isn't the best for these applications. i am sure that some of the other people on here could set you in a better way. these are just some of my recommendations.
16 years 8 months ago #14918 by DCurrin
Replied by DCurrin on topic holes and AR plate
Not personal experience but passed on information.
IF you need a 1" hole that is what you drill. NO stepping up as the drilling process hardens the metal. It is tough to start with..
:) :) D2 :) :)
Stuck Left Clutch, Dang
16 years 8 months ago #14921 by ccjersey
Replied by ccjersey on topic restoring 1952 D82U dozer
Whay not buy a cutting edge and modify it if necessary?
Or do you want to replace parts behind the bolt on edge or what?
16 years 8 months ago #14925 by cr
Replied by cr on topic restoring 1952 D82U dozer
Our steel yard carries "bevel edge" which is basically flat bar with an angle milled along one side of it. I believe the material is high carbon "plow steel". It works good for scraper buckets and such, but I don't know how well it would work on a dozer.
16 years 8 months ago #14929 by 560 farmall
thanks for all the infomation this is my first time posting on this site and a toolmaker and thought it would be cheaper to build cutting edges had no clue about prices
16 years 8 months ago #14964 by D4Doug
Replied by D4Doug on topic Cutting edges
Replacing cutting edges should not be that big a deal. I have not bought any in a few years, and steel has gone up but i don't think I paid $100 for new cutting edges for my CAT 12 grader the last time I replaced them. I wouldn't want to drill all those holes unless it really paid. Hopefully, there is a company like Wear Parts in your area that sells cutting edges and can fix you up.
16 years 8 months ago #14971 by ol Grump
Replied by ol Grump on topic restoring 1952 D82U dozer
The hard part of drilling new cutting edges isn't just drilling and countersinking the holes but squaring 'em up so the plow bolts hold like they're supposed to. That can be done with a torch if you're really careful and you'll be able to install and remove the bolts and nuts with only one wrench.
Time to create page: 0.153 seconds
