New member
New member
16 years 8 months ago #14875
by slurrydog
hi, all I just signed up and became a member.
I have a 5j D2 that I got not long a go. I am not much of a mechanic so i might be asking for a lot of help in the near future. Thanks for letting me join your group.
16 years 8 months ago #14884
by carlsharp
Hey Slurry lots of good info here and real helpful folks, they have helped me more times then they know. I would suggest using the search function on the above toolbar before posting, as new owners usually have similar questions, and they have been answered many times over.
Also there is a D2 registry at
www.antiquecaterpillar.net
where you can see who has the s/n near yours, who is nearby and what options are out there.
I bought my first Cat in late 2007 and currently have 8 so be forewarned the virus you have exposed yourself to...
16 years 8 months ago #14911
by slurrydog
thanks for makeing me feel at home. I have always wanted a D2 since I was a boy, I know that sounds sick but I have, anyway I finally got one although it is not running right now I think with a little luck and the help of this group it will live again. So thank you again for makingme feel at home.
Thank you received: 15
16 years 8 months ago #14932
by biggastractor
Welcome aboard,
You've always wanted a D2. Well, there's no reason to stop at just one. Besides the series goes up to D11. The guys here will help you you do everything but pay for it.
Good Luck
Biggastractor
Thank you received: 32
16 years 8 months ago #14953
by Jack
Hi Slurrydog. Profile says you are in Oregon. Whereabouts? I am in Hood River and run a D2 5J. Let me know if you need a look at something.
Jack
16 years 8 months ago #14956
by slurrydog
hi, jack iam in Cottage Grove, 20 miles south of eugene. My d2 is not running yet, so I might have to ask for your advice every now and than,such as a good local parts source. Would love to hear about your d2.
16 years 8 months ago #14995
by Jack
'lo again,
My D2 is an oldie but a goody. It was upgraded to D3 sealed rollers several years ago. I've had it since 1969 and have put a bunch of hours on it, though not so much any more. Right now I can't start it. The carburetor is dumping raw gas down in to the cylinders, probably something holding the float valve open. I've been having an absolute hell of a time with the present day gasoline. When I cleaned the filter I got one easy start out of it, but I suspect some of the varnish and crud went down the fuel line.
They used to say "Leave the rig in storage with a full tank to minimumize evaporation. Don't do that now. Drain the tank and run the carb dry. Likewise, run the tank down to nothing before you gas it up again so the varnish doesn't accumulate. It's a different world we're living in now.
I'll rerun a pic of the D2 running last snow storm, also my old D7 3T on a winch job last year.
Jack
16 years 8 months ago #14996
by OldNuc
If the carb has the old cork float coated with some black substance the 10% alcohol in the gas will soak through the black coating and penetrate the float. The float will sink. It takes a while for this to happen. The 87 octane fuel and a shot of Stabil is the best bet.
Thank you received: 6
16 years 8 months ago #15006
by ol Grump
A cure for those old cork floats is to dry 'em out for a few days, then coat 'em with a good fiberglass epoxy. I did that to the float in my old D2 several years ago and it's still holding. Also running the pony out of gas instead of shutting 'em off with the off-on switch with those old cork floats is a good idea.
New member
Time to create page: 0.194 seconds
