Pony exhaust pipe replacement Diesel 50 and D8800 power unit
7 years 7 months ago #163701 by STEPHEN
I have two pipes that need re-tubing. I found a good material supplier called stock car steel located in Mooresville NC. They have a vast selection of tube and other steel. I used 1 3/8" x .065 4130 Dom tube. A bit of channel served as a fixture to hold the tube in alignment with the cast elbow for tacking. I brazed the joint with bronze using the tig torch. I had to make a few small corrections in the angle by re-heating sections of the joint, checking alignment by clamping the flange to the table of the band saw. I plan on finishing with a light abrasive blast and silver VHT paint.
7 years 7 months ago #163705 by Bruce P
Very nice Stephen, when I redid the inner tube on my RD7 intake, I had no luck finding 1 3/8 tube. So i used 1 1/2 instead, then bored out the holes in the manifold. Seems to have worked. Of course no one can see it in there. Lol
BP.
7 years 7 months ago #163752 by mog5858
nice work. that Tig brazing is something i think i should lean. have done lost of gas brazing just not tig. do you run a flux? where you using silicon bronze?
7 years 7 months ago #163771 by STEPHEN
No flux, I have a box of bare rods, shipyard surplus. I will see if it is marked. It seems to wet out fine. I have been using it to hold split bronze bearing shells together for turning on the lathe. The original pipes had a non ferrous filler, I have seen some where the pipe was rotted off but the filler was still there.
--- both pipes(Diesel 50 & D8800) agreed on the length of 23" so I believe that is an original length. If anyone is needing that data.----
7 years 7 months ago #163777 by STEPHEN
Replied by STEPHEN on topic Brazing rods
Here you go
Time to create page: 0.157 seconds
