D4d
D4d
Thank you received: 820
16 years 8 months ago #14572
by OzDozer
The 3304 was fitted at S/N 82J2177. The D4D with a 3304 engine has a separate 78P**** engine number. Prior to 83J 2177, the engine model was the D330C, and the engine had the same S/N as the tractor. There are only slight differences in the appearance of the engine, between the 3304 and D330C, they are basically the same 4.75" bore engine.
16 years 8 months ago #14585
by rk d4d
Since the serial # for my Cat D4D is prior to 83J2177 the engine should be a
D330C. Where can I locate the serial # on the engine? How much is the horsepower for the D330C?
Thanks for the information!
16 years 8 months ago #14588
by OzDozer
The D4D was 65HP prior to S/N 83J1822 .. from 83J1822 onwards, they were upped to 75HP.
The engine S/N tag is on the LHS of the engine block (facing forward), at the rear upper corner of the block, adjoining the head gasket.
D4d
Time to create page: 0.157 seconds
