Old bolts
8 years 4 weeks ago #157005 by Pioneernorth
Old bolts was created by Pioneernorth
Took a break off the 14a. Finally got back to fitting the best rollers off the donor undercarriage. These rollers are definitely more worn than the ones that are near new. If i put a straight edge down the rollers where the links run the worn two that I am putting on are around 1/2 inch away from touching. Also tried to be cheap and reuse some of the old bolts to hold the roller on. Got the first one on and torqued up three bolts to 450 ftlbs. Last bolt snapped. Had them all coated good with copper coat and they looked alright but a little rusty. Now I get to weld a nut on to get the broken bolt stud out of the swing frame. Going to use new bolts. They're $15 each for genuine Cat. Grade 10. B
8 years 4 weeks ago #157008 by Dieselholic92
Replied by Dieselholic92 on topic Old bolts
Looks like quite the project! I really need to get the track frames off my D7 17A and find some newer segmented sprockets for it.
Thirty Five gas, D4 5T, D6 2H, D6 9U, D7 17A, No. 12 70D, 12E, 12E, 922B, 922B
www.dandgexcavating.com
8 years 4 weeks ago #157050 by razz
Replied by razz on topic Old bolts
I would look for some better rollers to match up to the other ones or get out the welder. Razz.
Time to create page: 0.145 seconds
