working on 8t grader
16 years 9 months ago #13833 by magnolia ranch
trying to service and repair neglected 8t, would like to find maintenance and parts books for it. thanks for any help jim
16 years 9 months ago #13836 by gemdozer
Replied by gemdozer on topic 8t
I Have a parts manual and a servicemen's reference book for grader 8t
<a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
16 years 8 months ago #15026 by WARBIRDF4
You Need A Service Manual, A Serviceman's Reference Manual, A Parts Book, And A Operations And Maintenace Instructions Book.
I Got Mine Between Ebay And Yesterday's Tractors 800 8532651
You Need Your Serial Number 8txxxx And Up.
You Should Check Oil In Transmission Right Away And Do The Washing Proceedure With Diesel Fuel Listed In Books.
It Is Reccomended That You Idle In High Range (foreward) With The H Shifter In Nuetral This Runs The Transmission Oil Pump Better. The Transmission Oil Filter Should Be Cleaned During Change And Bottom Suction Screen.
Lubrication Of Several Gearboxes Including Injector Pump Gearbox.
Most Of These Old Neglected Ones Are Bone Dry Or Dirty And Plugged Up.
Carbuerator Seafoam And Cleaner While Its Running.
Magneto Probably Should Need A New Condenser For Hotter Spark
Sometimes You Have To Buy One At A Tractor Store And Solder The Bracket On.
That Should Get You Started.
Pony Motor Oil Changed 1 1/2 Quarts
Engine Oil Checked On Dipstik While Running
Time to create page: 0.151 seconds
