checking after cooler leaks
17 years 3 days ago #13551 by earthgrader
how do you check a after cooler mainely on the water side, and if it is leaking what will it do ? if ti is leaking thanks
17 years 3 days ago #13560 by ccjersey
pressurize the cooling system for leak checking, flow test for restriction/scale or perhaps there's a spec on charge air temperature.
depends on how bad the leak is and what configuration the cooler is (above or below the intake runners on the head). Real bad leak/slow leak over time, could bend a rod on startup if there's a cylinder with water in it.
17 years 2 days ago #13575 by bob
Replied by bob on topic checking after cooler leaks
What engine is it on?
Later Bob
