- Thank you received: 0
Hi Rusty-
You may find some good info here:
www.acmoc.org/bb/showthread.php?25677-Cat-d6c-power-shift
Couldn't help but notice your maintenance manual is for later serial machines than yours, possibly after the change was made to turbocharged 3306.
Best of luck, my first job on a crawler was a late 10K and I blame it for me catching "the bug".
Hi rusty, is that a final drive leak on RH side in pictures first posted? Get a bar between sprocket and housing,if any movement bearings need nipping up and or replaced. Repair manual should show what's involved. Nice machine good luck with it..... Bill:thumb:
Hey RB88,
The studs sticking out the side of the hard nose on each side are to hang the cylinders on if you drop the blade. There are small brackets on the inside of dozer cylinders. If you were to remove blade, lift cylinder up with chain and hook brackets to those studs to hang cylinders for safe keeping until used again.
Glen
support@acmoc.org
- Chris R
- Jason N
