D6 9U pup engine removal
16 years 7 months ago #13130
by d7doug
Does anyone have any pics showing how to remove D6 9U starting engine, the thrust bearing is done and the pup seems to keep locking up. Any advice on puting electric starter in?
Thank you received: 10
16 years 7 months ago #13133
by ccjersey
drain the pony motor oil
drain the main engine coolant
unbolt it all and lift it off:D
Not a big problem except for getting ALL of the nuts or bolts holding the pony motor block down to the clutch housing. Dig all the accumulated grease and dirt out between the pony motor and the main engine head to find the last one before you try to lift it up.
Old magnet will probably be along to give you the link to his pictures and explanations of the in's and outs of electric start conversion.
First thing to find out is- Do you have a clutch housing with a hole for a starter below the pony motor clutch and pinion?
or will you have to make one?
Thank you received: 790
16 years 7 months ago #13213
by WARBIRDF4
I Could Scan And Email The Proceedure For A # 12 Motor Grader They Are Close To The Same
Time to create page: 0.130 seconds
