Holt serial no
Holt serial no
16 years 7 months ago #13041
by Omnitrac
I have a early Holt 2 Ton that the serial number tag is missing, which I assume was orginally located below the seat as was done with the Cat 2 Ton, but there is no sign of rivets.
Does anyone know if the serial number was stamped in the frame in another location.
I have a engine serial number is there anyway htis can be used to determine the year.
Dennis Wilkinson
<a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
541 963 0139
16 years 7 months ago #13089
by milzy
Dennis, you are correct that the serial number plate was located under the seat the same as the Cat 2-Tons. It was however a smaller plate measuring 4" X 6" whereas the Cat 2-Ton plate was 5" X 8". I don't know if there is a way to determine date of manufacture from the engine number. My engine number is close to my serial number but not the same. One place you could look for a date is on top of the bell housing. You'll have to remove the fuel tank and the plate it sits on to see. Two of the Cat 2-Tons that I have, have a date in the casting at that location along with the part number. One is very clearly 9-11-26, and the other is ?-??-28 so I have to believe they are casting dates. The third one has the spot where the numbers were but they are not legible. My T-35 has no legible numbers there either but there is a spot that might have had numbers at one time. Hope this helps. Dave
Holt serial no
Time to create page: 0.131 seconds
