Cat Ten Carb.
16 years 11 months ago #12942 by hicrop10
Cat Ten Carb. was created by hicrop10
I have both a std. ten and a hi ten, both run but when they sit around for awhile like over the winter months the carbs always seems to give me a problem. Is there anyother carburator out there that will fit these tractors? Thanks for any help.
16 years 11 months ago #12943 by WyoCat
Replied by WyoCat on topic Cat Ten Carb.
There is no direct easy replacement. I have seen anything from an updraft Marvel Schebler to a side draft DLTX off a JD H installed on a TEN. Maybe someone else knows of something.
Chad Enyeart
16 years 11 months ago #12946 by SJ
Replied by SJ on topic Carb.
There is a fluid called Sta-Bil to add to gas to keep it from causing storage problems with gas so you might try it. Hardware stores usually keep it possibly garden tractor dealers and if you have a fuel shutoff from the tank try shutting it off before shutting the tractor down and let it burn all the gas out of the carb. I do this with my snow blower and it always works between storms and when it,s in storage over the summer and fall, just a thought.
16 years 11 months ago #12951 by Catmatt
Replied by Catmatt on topic Cat Ten Carb.
mike,
Might be a problem with this new gas they have anymore. I have noticed I can't leave gas in the fuel tanks for more than a couple of months or it will go bad. Prior, i could leave gas in the fuel tanks all winter with no problems.
16 years 11 months ago #12952 by OldNuc
Replied by OldNuc on topic Cat Ten Carb.
That is what happens with the new oxygenated fuel. There is about 10% ethanol blended into the fuel. In some states they do not mark it on the pump. Using Sta-Bil will retard this fuel degradation.
16 years 11 months ago #12953 by side-seat
Replied by side-seat on topic Cat Ten Carb.
Mike, Send me those unwanted carbs.
16 years 11 months ago #12955 by Willie
Replied by Willie on topic Cat Ten Carb.
I have seen the with many diff cars the Model T carb and few sports cars are side draft just bolt it up or or get a short 1in. sweet and weld flang on each end then you can use up draft one from a 9N , Wis, V4 or anyonter small engine and you can sell me the 10 carbs for enough to but the other stuff new
16 years 11 months ago #12978 by naylorbros
Replied by naylorbros on topic Cat Ten Carb.
My PV Fifteen had a carb off of a 200 CID. Ford Falcon engine on it when I got it. The tractor ran very well with that carb, but I did not leave it on very long. I kept the set up for a few years that then tossed it.
Ken
Time to create page: 0.149 seconds
