D4 7u fuel primer pump
8 years 3 months ago #136363
by kylerose
Just wondering if anyone has a part number or availability of the hand operated fuel primer pump that would have come on a d4 7u with electric start. I've been looking around and can't find the information I'm looking for . Any help would be appreciated thanks
Kyle
8 years 3 months ago #136367
by Hillbillybjopkr
there is a picture of the priming pump in my operations manual.....bottom left corner of the pic has a number T21012 not sure if that is pic number...or maybe a part number....hope this helps
Thank you received: 25
Thank you received: 202
8 years 3 months ago #136374
by Mike Meyer
My 7U27570-Up book shows a 5H9877 Fuel Priming Pump Group on tractor 7U28232 for use with 24 volt starting or 5H9869 Fuel Priming Pump Group for 24 volt starting with fender mounted fuel tank, if you need individual part numbers of the unit sing out. I had a quick look on Parts search and none of those 2 numbers show as available anywhere though searching individual parts shows availability, look for
4F7762 Base
2H2483 Barrel assembly (pump)
7B8633 Cap (of pump)
7B8517 Handle assembly
It looks IHM Used Parts might have bits you need, try them on 888 53528 one seven
Good luck
Mike
8 years 3 months ago #136377
by kylerose
Thanks I've been looking at those brass pumps wondering if that's the easiest option . OM if you read this , would you by chance be able to post the missing pictures from the link page . Thanks
Thank you received: 737
8 years 3 months ago #136383
Those original hand priming pumps are not worth fixing unless your bent on original. The pump barrel and piston rod is steel and usually are badly corroded. In that state the barrel just tears up the plunger.
Here's the missing pictures, choice of fuel gauge or hour meter in the bracket or just the pump.
I see the BB is back to loading picture sequence backwards again. Worked right for a while.
Thank you received: 9
2 months 1 week ago #255361
by candoman
Hey Old Magnet I cant get those pictures of the primer setup you did.Could you repost them?It would be much appreciated.I purchased one of those brass pumps on ebay but could use a little help hooking it up. It has a check valve in the inlet side of the pump I'm installing it on my 1953 serial number 7/U 25012 Thanks Again!
Time to create page: 0.193 seconds
