Oil Leak on 17 A
16 years 10 months ago #12581 by Old Magnet
Replied by Old Magnet on topic Oil Leak on 17 A
Hi Ali,
Afraid your SOL:D The bolts/studs are nicely located low and behind the flywheel. Might be able to reach one through the timing pointer cover....maybe.
16 years 10 months ago #12622 by ali sleiman
Replied by ali sleiman on topic Oil Leak on 17 A
Hi Old Magnet,
Too bad , it will have to wait till the next clutch change
Does anyone have a source for track covers for 17A
Thank you
16 years 10 months ago #12708 by ali sleiman
Replied by ali sleiman on topic Oil Leak Update
:) We had agood day today, in addition to few successes, I found the source of leak . The oil is leaking from around the compression lever. On this machine it sit high on the right side of the big engine. The oil run down the area of the block behind the air filter. also found another leak if from the oil pressure gauge line.
These 2 problem are easy fixes:cool: :)
16 years 10 months ago #12711 by Old Magnet
That's a hell of a lot easier than dealing with the flange gasket:D :D
Thought you had already looked for the obvious sources as mentioned early on in the posts.
The decompression shaft seal is a 7B280
16 years 10 months ago #12720 by ali sleiman
Can the seal be reached and changed from outsidewhen taking out the decompression lever
16 years 10 months ago #12728 by Old Magnet
I'd say yes but it will take a little fishing..........and cussing:) :)
16 years 10 months ago #12766 by ali sleiman
Hey Old Magnet,
I checked the part number for the seal from my source , it is available and my cost is $1.00 . I think I will get few seal just in case the cussing got out hand
Time to create page: 0.161 seconds
