D4 Model Number Information Needed
17 years 11 months ago #1154
by xzp0hy
I have become the recipient of a D4. I need information on how to find the model number. I found, cast on the left side of the engine block 6F3787. I am trying to verify if this is the model number. Also, if anyone has information where I can fine the serial number, it would certainly be helpful. I have no operation or maintenance manual so I hope I can fine same. Any help would be appreciated.
17 years 11 months ago #1155
by Willie
Here you go even if tag is not there scrape away paint it will be stamped in casting where tag was look for 4G,7J,2T,5T,6U or 7U
17 years 11 months ago #1158
by xzp0hy
Thank you for your reply. I will follow your instructions. By the way, if you have any suggestions on finding a source for operating / maintenance manuals, please let me know.
17 years 11 months ago #1159
by xzp0hy
Not sure I posted my reply correctly but wanted to be sure you received my reply. Willie, thank you for your reply. I will follow your instructions. By the way, if you have any suggestions on finding a source for operating / maintenance manuals, please let me know.
17 years 11 months ago #1160
by Willie
First off you need to find out what you have? ser. no.? every seires is diff and in each of those there are many changes, the D4 was most change tractor of any in its run so when you get a book make sure it covers your ser. no. not just the seires. They are always on EBay fairly cheap and easy to find D4 books. There are some on right now.
Thank you received: 814
17 years 11 months ago #1181
by Willie
OM how did you get that to post I have posted it many times on old site but wont work here do I have to resize every pic in my file to get it to work on this BB
Thank you received: 77
17 years 11 months ago #1182
by bernie
On my D42T there is also a brass tag with identical stamping on the starting engine left side right above the starting pionion lever. It is from when the tractor was taken to the Granite City Engineer Depot for work. They tagged the main and the starting engine identically. My winches cover the rear tractor stamp. Someday I will see what it is.
bernie
Time to create page: 0.166 seconds
