Gear Oil--212 Grader ??????
16 years 10 months ago #11887
by LeakyBoot
Don't have a manual. Need to go over the newly purchased 212 and top off all the gear and chain boxes. Think I'll buy a 5 gal bucket and see if that gets me started. What weights are used in boxes like the incab controls and the chain drives--just for starters. 140wt?? Thanks LB
Thank you received: 10
16 years 10 months ago #11893
by ccjersey
I would use gear lube in everything except the engines and pony motor pinion clutch. I think a couple of the gear boxes on the circle etc use grease, but you will find fittings on those.
On ours, I found a significant amount of water contamination in the large blade lift boxes mounted on the front of the cab. Ended up draining those completely. Don't forget the angle box just under the floor that turns the power shaft up to go into the bottom of the blade controls box.
Also notice the oil cup for the clutch release bearing which takes gear oil every day.
The steering box is a common problem area, so you should take the first opportunity to make sure the bearings on the input shaft (worm) are good and don't have excess slack. If there's a bearing loose, the worm will climb the end of the rack and break itself. $$$
Time to create page: 0.126 seconds
