Flame out
16 years 11 months ago #11836 by Eric Egland
Flame out was created by Eric Egland
This happens when the final straw, the one extra diversion confronts the operator. Not even close to a problem, but annoying.
You don't need this when flying, as bad things can follow the last overload event.
Dead silence and flooded pony. So, go get another tractor to dig this one back to a fairly level spot.
The last time was same side angle, but pointing uphill. I used a hand operated logging winch to pull it out. 15 years ago.
It won't happen again.
16 years 11 months ago #11862 by DCurrin
Replied by DCurrin on topic Did it too.
New owner D2 5u.
Put on the electric starter, that PO never did. :)
but no battery installed.
just temp it on the track then take it back off.
Great if I did not stall it.:mad:
Get battery (big 8D) back out and hooked up and try it again.
Put battery away and try driving it again.
better luck this time.
Oh well, misery loves company. At least you had something else to rescue with..:)
Tractor looks pretty good,, Any pictures to email or posted anywhere.
Looking for reference photos. So I can get mine on the better looking list.
Stuck left clutch. Dang
Cheers
Dudley
:) :) D2 :) :)
Stuck Left Clutch, Dang
16 years 11 months ago #11869 by B4D2
Replied by B4D2 on topic Flame out
Sometimes, it's not flooded, just the tank is a little low on gas and the angle is preventing the fuel from getting to the elevated fuel line outlet. Try adding a pint of two of gas to top off the tank next time. Same angle, same problem for me, added a bit of gas and away she went.
16 years 11 months ago #11871 by TerryinNorCal
Replied by TerryinNorCal on topic Flame out
Same here with mine B4D2, so check that Eric. Been on all kinds of slope in mid/northern California, in all directions. When quittin time came around, it came around! Only gripe I have with a pony pull is when yer on the trailer tryin' ta balance and still get a "full pull".
16 years 11 months ago #11882 by Eric Egland
Replied by Eric Egland on topic Well....
Well, I've only got about 1000 hours on this D2.
The first thing I did was to crack the downhill petcock and notice that a straight stream of gas was squirting out of the cock. BTDT.
I did actually try a start, but it was hopeless.
Rather than waste time, I drug it over to a "flat" spot. I always wanted to convert to direct electric start, but this one starts first pull, every time. So, I allowed the electric start urge to fade away.
After changing oil and topping up the pony tank, started right up.
The real gist of the post is to try and avoid dealing with too many details, causing an unwanted result.
Eric
Time to create page: 0.153 seconds
