D2 5U manifold modification
Thank you received: 32
17 years 11 months ago #1058
by Jack
I'm into a D2 5U engine, found that the intake manifold has been drilled about 5/16" opposite every cylinder head port. Yup, you understand that correctly--a hole over every port to be sure dust got into each cylinder equally, unless there was some attachment that I've never heard of that plugged these holes. Any ideas, anyone? It was a pony start tractor, but could these have been glow plug heater holes? They arn't threaded. I sure never have seen anything like it before...
Jack
17 years 11 months ago #1063
by SJ
I never saw or heard of a manifold being drilled like you described. Maybe someone did this for a reason after they got the tractor but all the glow plugs I ever saw were up in the precombustion chamber along side the fuel spray nozzles.If they are open to the inside of the manifold then yes you can,t let it go like that as it will suck in dirt & dust from the outside atmosphere. Either repair the holes or I,d look for another manifold.
17 years 11 months ago #1070
by Dave
Jack, I have two later D2 5U's that have holes in the exhaust manifold, not the intake by each port on the bottom. There more like 3/16 or smaller. I think they are moisture drains.
Dave Smith
Smith Mountain Ranch
Woodburn, Oregon USA
Thank you received: 814
17 years 11 months ago #1071
Nope,
Thats a new one on me. Was the air/exhaust heat exchange tube intact?
Somebody embarked on air heaters, water or fuel injection????? Who knows:D
Any other strange plumbing on the engine???
5/16 is tap hole for 3/8 NC thread??????
17 years 11 months ago #1075
by Manx Kat
Why not just tap and thread the holes and turn in a short bolt to plug them.
easy quick and safe compared to welding or looking for a different manifold.
D.K. in S.K.
17 years 11 months ago #1116
by Jack
OK, Thanx guys. Maybe I have seen everything now!
The engine was a take-out, I never saw the pipe from the air cleaner. I don't know what might have been there other than standard.
I came to the same conclusion--easiest & best to tap and plug or get another manifold.
I saw air plenum heater on Onan air-cooled diesel engine, but it was nothing that would go through such a small hole. It heated enough air for about two cranks over. I don't think that could be it either.
17 years 11 months ago #1135
by Ken1945D2
Hi Jack,
I think threading it is a good idea like Manx Kat suggested. You get to keep your original mani. and there's no cost. I like keeping things O.E.
The 5/16" holes are almost perfect to accept 1/8" NPT pipe plugs. Drill size is 8.75mm or 11/32" .(0.3438") ..which is one size up. Use socket head (allen) type plugs which will be flush when installed..no ugly bolt head sticking out, which you can fill small hex hole too with JB weld so you can't see the plug anymore. Just a thought. Very sexy repair;) . Put lock-tite on theads too.
Hope this helps and good luck!
Ex-Jaguar restorer Ken
THE IRON PILE:o
1939 Ford 9n
1945 Cat D25J
1955 Dodge M37 Military
1967 Bombardier SW48
1972 MF 50A Backhoe
17 years 11 months ago #1212
by pete22230
Just wondering if the holes could have been for some sort of ether injection for cold starting. I'm pretty sure they offered such an option but i've never seen one so no idea of how they were ported. Personally I would have thought a single injection point farther up the air flow but just a guess. Pete
Time to create page: 0.158 seconds
