Oil slick's tilt cylinder pump
9 years 7 months ago #124695
by Paso Bob
Thanks for giving me the shaft info Brian. I take it you would rather have a key way already cut into the shaft. I will look for a pump that will work CW or CCW like you mentioned above. I'm planning on keeping the GPM between 5-10.
Jack, the pump will be limited to operate a tilt cylinder only and possible use will be maybe 5 times per hour during dozing. Hopefully it won't put a lot of strain on the timing gear. My wood splitter pump is about the same size and it is powered by a 5 horse Honda engine.
Thank you received: 824
9 years 7 months ago #124696
Interesting comment on replacing the fiber pins with brass. These pins are not supplied as shear pins. They are actually listed as "cushions" and are most likely there to deal with the harmonics of the early gear trains before the addition of dampers and balancers. These "cushions" were eliminated on later engines. Be interesting to see how the pump holds up under operation. The pumping action (under pressure) will actually supply some dampening but not when it's in open circuit circulation mode.
I don't think I'd be to concerned about pumping 5-10 gpm at typical 1,000 psi max. which should be plenty for a tilt cylinder but I would hesitate to think of this becoming a major pumping system.
9 years 7 months ago #124699
by Oil Slick
Paso B, after I pulled the generator off I rotated the fan CCW while watching the gear rotation. The gear that the generator rode on was rotating CCW. Sitting in the operators seat the generator tuned clockwise.
9 years 7 months ago #124711
Paso Bob!!!
Note my correction to the generator rpm. Had my gear ratio reversed on original calculation.
9 years 7 months ago #124751
That's interesting. In one of the earlier posts Brian stated he didn't know the pump specs and that he obtained the pump from you????
9 years 7 months ago #124753
by Oil Slick
When I went back east to get the 40 scraper a couple years ago I stopped at Brian's on the way home for the night. I told him my plan of of putting the tilt cylinder on the D8 and that's when he gave me the pump. Next I saw Brian at the Santa Margarita show and I told him my machinists can't figure it out. Brain said ship me the generator and A pump and I'll getter done. That's how Brian got his pump back
9 years 7 months ago #124770
by Paso Bob
Old Magnet, would your revised shaft speed at 2,664 RPM's be too fast for a typical low volume hydraulic pump? Brian, any comment on keyed shaft or not? Thanks, guys!
Time to create page: 0.201 seconds
