D4 7u clutch.
D4 7u clutch.
16 years 9 months ago #11512
by d2davie
I was wondering if anybody knows what could be causing a ringing sort of noise coming from the clutch area of a d4 7u dozer, it makes this noise with the clutch engaged or disengaged.Work done to it so far is a new clutch driven plate and the linkages freed off and the pilot bearing packed with fresh grease, the engine was started with the clutch assembly oot and the noise wasna there but I cant see much wrong with the clutch itself.Any help on the problem would be appreciated thanks.
Thank you received: 790
16 years 9 months ago #11524
If it's making the ringing sound all the time I'm thinking something is touching the flywheel. Check to see if all is well with the pony clutch and pinion engagement operation......or starter drive if direct electric start.
Thank you received: 10
16 years 9 months ago #11525
by ccjersey
too long a bolt threaded into the flywheel area so that it contacts the flywheel or clutch?
Can you rotate the diesel by hand or indirectly by pony flywheel (by hand) and listen for the noise?
16 years 9 months ago #11603
by d2davie
Thanks for that OM and CCjersey I will have look at the starter pinion first, just thought it might be a slack ring gear, Thanks again.
16 years 9 months ago #11604
Also check to see if there is some misplaced item laying in the bottom of the bell housing that could be rubbing on the flywheel.
D4 7u clutch.
