Direct start Pre-cup with broken glow-plugs
16 years 11 months ago #11817 by ccjersey
OM,
What is involved in converting the D315 PC chambers to fit. If it's just a matter of turning and threading, maybe that would be the quickest way. Aren't these readily available and cheap too? The regular ones for the D318 are about $25 or less (aftermarket) I believe.
These new style, one piece, non-glowplug type I see for the D318 look like they have plenty of metal to do some modification on the diameter of the threaded end and the top where it seals in the head with the o-ring. How about the height? I assume the D318 would be taller, but is the D315 that much taller than the D311?
16 years 11 months ago #11818 by Old Magnet
Hi CC,
As I mentioned earlier, there is no problem getting aftermarket D4/D6 glow plug chambers and the contact Dunefenatic mentioned is a fellow near by that rethreads the nose to fit the D2 head. As for as I recall the rest of the dimensions work and uses the same glow plug. I'm pretty sure that's what will wind up happening.....but some of those suggestions are interesting.
One won't work for sure and that is trying to make a glow plug chamber out of a regular one. Just doesn't have enough meat in the right place to accept boring for the glow plug.
16 years 11 months ago #11865 by D2Dwyer
Are these D2 glow plug pre chambers used on electric start conversions? Does anyone have a picture of one they can post here?
16 years 11 months ago #11906 by mkreh23
Where can I order aftermarket precombustion chambers for glow plugs for a D315/D318? I have the same problem with my 933 11A loader as the others on here and if the new ones that I need to modify that are only $25 I think I might invest some time and see if I can modify those to work in my D311. Also if I can get the aftermarket ones to work I will have a 2 maybe 3 of the original D311 ones for sale. Thanks.
16 years 11 months ago #11908 by ccjersey
Try Regal corp. (See parts source posting at the top of the board for website address or google it).
I have only ordered a few things from them, I used a credit card, though they have an application type page you have to submit to even use a credit card. If you have part numbers you talk to the order folks, if you need help, there are tech service folks that can look them up for you.
Sorry I don't have anything with a D315 engine so I can't check the number for them.
D311 3H2037 chamber
D318 3H2209 chamber
16 years 11 months ago #11909 by SJ
Replied by SJ on topic Chamber
CC the D315 chamber is the same one as the D318 the 3H2209. Heads are the same except two more cylinders on the D318 head.
16 years 11 months ago #11918 by Old Magnet
mike reh23,
The D6/D4 one piece glow plug chamber number you need is a 1S1970.
Try Regal, Costex or Heavyquip.
The thread is a 1-1/8 dia. 12 tpi. which would need to be changed to a 1" dia. 12 tpi to fit the late D2/11A933. All other dimensions are the same.
16 years 10 months ago #12428 by Old Magnet
Hi Greg,
Finally found my notes on the pre-com chamber threading contact:rolleyes: :rolleyes:
It's Neal Wolleson
831-385-4655
I think the phone number is different than the one Don has.
16 years 10 months ago #12438 by Dunefanatic
Thanks Pete.
I need to contact Don to see if his machinist had any luck or had a bad day? Greg
16 years 10 months ago #12576 by STEPHEN
Replied by STEPHEN on topic Hobby Shop Needs Work
:D I would be happy to rethread some precups on the lathe as needed-CHEAP!
