5 Day Dozer
17 years 1 week ago #11048 by carlsharp
5 Day Dozer was created by carlsharp
For those of you following along, this Cat should be like a nephew by now. It first started with the "D4 on ebay HELP NOW" thread, and then in "Single Cylinder D4".
In KoO fashion it is now known as "The Nudist" because it was found stripped at a nudist colony.
Now I have a running main engine, 5 pallets of parts, and a playday in 5 days. It was supposed to be fully functional when they took it apart.
Do you think I can have a dozer by then? Follow along and see.
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: www.youtube.com/profile?user=carl4043
17 years 1 week ago #11049 by carlsharp
Replied by carlsharp on topic Monday
Got it running, got it home.
Drained the trans/bevel case (water in oil)
Adjusted main and steering clutches
Adjusted steering brakes
Replaced covers on rear (5)
Greased some
Install drawbar
Carl Sharp
Chino, CA
17 years 1 week ago #11050 by carlsharp
Replied by carlsharp on topic Tuesday
Picked up woodruff key and set screw for hyd pump shaft
Installed:
All floor tins
Fan shroud
Grille
Clutch cover/throttle link
Hyd pump (took the torch to get the nuts off the studs)
Hyd tank/valve
Hyd lines (loosely)
Hyd rams
All this after working all day...
Carl Sharp
Chino, CA
17 years 1 week ago #11054 by gwhdiesel75
Replied by gwhdiesel75 on topic 5 Day Dozer
Carl, glad to see your progress. Why to heck did that "strip" the tractor? Keep up the good work and keep the photos coming. GWH
17 years 1 week ago #11061 by David Wills Cat 60
Replied by David Wills Cat 60 on topic 5 Day Dozer
Carl,
Thanks for giving us an update on your progress, what series is the tractor is it a 5T?
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
www.flickr.com/photos/link_club/
17 years 1 week ago #11063 by equipdriver
Replied by equipdriver on topic 5 Day Dozer
Heck with the cat, where are the pics from the nudist colony.:rolleyes:
17 years 1 week ago #11065 by Macca
17 years 1 week ago #11078 by carlsharp
Replied by carlsharp on topic 5 Day Dozer
GW- the owner died mid rebuild
David- 5T158
Driver- no good naked there
Mac- TOOfunny
Carl Sharp
Chino, CA
17 years 1 week ago #11079 by carlsharp
Replied by carlsharp on topic Wednesday
Picked up new hose for hyd supply. $14 a foot!!
Installed ^ hose
Tighten and mount hyd lines
Drain finals, fill w/diesel
Man what a pain. The hyd supply to the pump is hard lined with 5 els including one homemade with a 'special' angle. Took like 2 hours to get everything to line up. Plus nine unions to make up.
Carl Sharp
Chino, CA
17 years 1 week ago #11088 by carlsharp
Replied by carlsharp on topic Thursday
R & R valve cover, replace gasket
Flush/fill finals
Fill hyd system
Drag start, cycle hyd's, everything works! 2 hoses leak
Get hoses made, R&R
Refill hyd's
Install hood, muffler, precleaner
Make a 2 5/16 pin out of 2 3/8 stock- with a grinder!
Install dozer frame, blade and angle struts
Attach lift links
Believe it or not....
Ladies and gentlemen, I am proud to introduce..
The FOUR day dozer!!!
Carl Sharp
Chino, CA
Time to create page: 0.156 seconds
