1941 D7 7M Dozer
10 years 2 months ago #113743 by Raeme
1941 D7 7M Dozer was created by Raeme
Hi all I've been on the site for a awhile. Thought I would post some photos of the old Girl. Also has the three Tyne Letourneo rippers with it.
10 years 2 months ago #113745 by stevens205
Replied by stevens205 on topic Cool dozer
Nice looking old dozer bet she can push some trees over :)
10 years 2 months ago #113746 by Jw74
Replied by Jw74 on topic 1941 D7 7M Dozer
thanks for sharing do you still use them?
Thanks God Bless
10 years 2 months ago #113747 by Raeme
Replied by Raeme on topic 1941 D7 7M Dozer
Hi. Yeah they both still get used. The one beside it is a hydraulic D7E. Both push everything in front. I used the E on fence line contract work and the Cable one is for my place.
10 years 2 months ago #113793 by D6c10K
Replied by D6c10K on topic 1941 D7 7M Dozer
My brother has the D7 7M my Dad bought back in the early 60's...I was told it was a 1940 but I'm not sure. It's had a hard nose & hyd lift cylinders added. Not sure if the blade is Cat or not....the push arms are rigid mounted to the blade. Tracks are pretty tired.... Hasn't been run now for several years, but he keeps the water out of it so with a day or so of fiddling with the mag I think it will still go.
10 years 2 months ago #113794 by willitrun
Replied by willitrun on topic 7m
picked over carcass of 7m1029 here. I was told it was a 1940. poor old frame has enough welds on it to make Lincoln electric proud. I'll bet it had a multitude of operators. from the looks of it, some good-some bad
10 years 2 months ago #113807 by OzDozer
Replied by OzDozer on topic 1941 D7 7M Dozer
Raeme - That old girl is in pretty good shape, the undercarriage looks very serviceable. With that LeTourneau blade, overhead cable guide and LeTourneau PCU, I'll wager she's likely to be a WW2 hero.
Any sign of military olive drab under the yellow? Have a close look at the S/N tag, or on the upper rear face of the steering clutch housing, for a stamp that says "US7".
If it has "US7" stamped there, she's been part of the U.S. Seventh Fleet that was based on the East Coast of Australia during WW2, and which fleet fought the island-hopping war against the Japs in the SW Pacific.
These tractors were either transported via landing craft, usually LCT's (Landing Craft, Tank) or LCM's (Landing Craft, Mechanised) to the islands, to carry out airstrip construction and repair, and to bulldoze out pillboxes and bunkers.
If they didn't do that, they were kept here in Australia to build airstrips for the Allied effort. Over 300 new airstrips were built during WW2 in Australia, with nearly all of them capable of taking the largest of the American 4-engine bombers.
At the end of the War, some were destroyed due to Lend-Lease regulations, and the rest were sold to the public via the dozens of Disposals Commissions Sales held between 1946 and 1949.
Regards, Ron.
10 years 2 months ago #113808 by Bruce P
Replied by Bruce P on topic 1941 D7 7M Dozer
Not a bad looking tractor at all. What's the serial number? I've got # 298 here. It had a very similar blade and CCU when I got it. Just like Willitrun said about his, mine has had a lot of welding done to it. Thanks for sharing.
Bruce P
10 years 2 months ago #113822 by Raeme
G'day all. Thanks for the replies and kind words. Yes it was olive drab under the yellow. I'll check for the us fleet markings and let you know. The chassis is in good nick on this one. I've replaced the radiator, clutch, steer brakes, track adjuster and rebuilt water pump. I'm waiting on a local cat guy to come out and we are going to rebuild the RH final. Looks like it might have dropped a bearing, you can rock the sprocket with a crow bar. It still has original pony motor and runs like a button. I can dig all day and the temp never goes over half, she burns no oil and runs clean as a whisper. She has a fantastic bark out the stack when you stab the thottle.
Also the serial number is 7m9506SP
10 years 2 months ago #113823 by OzDozer
With a S/N of 7M9506, she's a 1944 model and near the end of 7M production. S/No's for the 7M ended at 7M9999 around August 1944 and the next tractor off the line was 3T0001.
The transition from 7M to 3T series was seamless and there were only a few minor design changes when the 3T production started.
The SP indicates factory-installed attachments - quite possibly a full set of lighting and a heavy duty generator. They worked these tractors around the clock when the pressure was on.
