cat D8 r info
17 years 3 weeks ago #10726 by MARTYN WILLIAMS
Can anyone help by posting a cross section drawing of and engine block off a 1944 D8. Also looking for a diagramme of the combustion chamber area?
Many thanks
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 3 weeks ago #10727 by Old Magnet
Replied by Old Magnet on topic cat D8 r info
With screw in or pressed in pre-combustion chambers?
Had this one on file.....could swear that I posted it for you before:) :)
17 years 3 weeks ago #10728 by Willie
Replied by Willie on topic cat D8 r info
Well the post is confusing to me he asked for a pic of block with combustion chamber which is the cly. you post a pic of head with the PRE combustion chamber, what does he want ?
17 years 3 weeks ago #10729 by MARTYN WILLIAMS
Replied by MARTYN WILLIAMS on topic cat D8 r info
Hello,thanks for your help.Sprocket is overhauling his D8.Gave him the drawing that you posted on this BB some time ago but he mislayed it.He has been getting all the parts overhauled for the rebuild.He wants to check the engine block for fractures before its reassembled,so he is also looking for a diagramme of the engine block so that he can tell the person doing the checking where to look.He also wanted a drawing of the cyl head cross section which you supplied.Many thanks for posting it.He is collecting a refurbished crank shaft on Saturday.I will post pictures as the rebuild takes place.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
17 years 3 weeks ago #10733 by tctractors
Replied by tctractors on topic Try reading the post.
Willie if you read Martyns post correctly , he ask's for a picture of the engine block also the combustion area, perhaps things do-not translate to good
tctractors
17 years 3 weeks ago #10735 by tctractors
Replied by tctractors on topic Book sent,
To help Spocket with his full engine / tractor rebuild I am sending him a Service manual also (at some great cost) I am going to travel to Cardiff and pull his tractor to bits.
tctractors
17 years 3 weeks ago #10737 by Willie
TC I read it very carfully thats what didnt make sense if he got the block pic he would have the combustion chamber (the cyls), what got was the head pic ( the precombustion chambers) theres a big diff my friend many diesels dont even have precombustion chambers.Is the key word precombustion here or combustion chamber
17 years 3 weeks ago #10739 by Old Magnet
Martyn,
Don't have much in the way of block cross sections but with the wet sleeve on the inside, what you see on the outside is pretty much it. Also the combustion chamber normally associated with the cylinder head is pretty much flat with the only depressed area for the valves. Check for cracks running between valve seats and into the pre-com chamber opening.
17 years 3 weeks ago #10744 by MARTYN WILLIAMS
Thanks for all your help, the last time I saw the cylinder heads one of the valve seats were in a bad way.I think he has has this sorted out this week.Only hope that it was a good repair job because if it fails it could be an expensive bill with damage to all the new bits he is fitting to it.
Hello Tony,glad you are going to give him a hand.At £4.00 per hour he has got a bargin.Hope to see you soon.I am mobile now,only on one crutch.
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Time to create page: 0.169 seconds
