Cat service press tech info.
17 years 3 weeks ago #10621 by dead axle
Hello all
I have a Cat service press double acting puller type. We always called them a pancake. It is part number 7F9540. I believe it is a 30 ton. Do any of you happen to have any tech info on it. I'm looking for cylinder diameter and rod diameter. I'm trying to figure the displacement tonnage when used with a 10,000 lb O.T.C. pump (how many pounds equals how many ton) Thanks in advance..................
17 years 3 weeks ago #10623 by Old Magnet
I show it in the Cat service tools as a 30 ton, 10,000 psi max. working pressure unit, along with parts breakdown but it does not give either piston rod or cylinder diameters. It is a stepped cylinder/rod so it seems you would have to open it up to check the cylinder diameter.
17 years 3 weeks ago #10624 by josh
Replied by josh on topic Cat service press tech info.
Here is a decal/chart for a Cat 30 ton double acting hollow cylinder, the numbers for the psi to tons should be the same as yours, these figures are for the rod pushing out, the tonage for pulling in is slightly lower.
17 years 3 weeks ago #10632 by dead axle
Thanks to you both. That is very helpfull
Time to create page: 0.134 seconds
