1950's caterpillar d4 questions
10 years 4 months ago #110003 by McMOPAR
Track pins are 27" from center to center over 5 pins, and I took a video. Also detailed pics to come...
10 years 4 months ago #110004 by McMOPAR
Here we go...
10 years 4 months ago #110005 by Old Magnet
Did you stretch the chain before measuring.
27" would only be 5% worn and I doubt it is that good.
10 years 4 months ago #110007 by Jim Davis
I noticed the brake pedals too.
I also noticed new nuts on the gear shift quadrant. The 6U I owned (and liked very much) had a habit of hanging up in reverse with the stick moved into neutral. Then I had to remove those nuts and either move the transmission to neutral or the stick to reverse. It only did that when I shifted too quickly or vigorously out of reverse.
But new bare-metal nuts on that quadrant when everything else is painted looks suspicious to me. If all else checks out OK, be sure to drive it and be a little aggressive shifting out of reverse, just to see what happens. Having that reverse in neutral issue is not a deal killer to me, because it can be fixed by building up the bottom end of the gear selector stick, but it IS a nuisance.
Jim
10 years 4 months ago #110008 by ol Grump
As has been noted about wear on the brake pedals and new nuts on the shift quadrant it appears to be a well used machine.Unless my eyes are worse than I think it looks like a new sprocket ring has been welded on and possibly the track chain has been replaced. .at least on the side in the picture.
I'd be curious as to what the hour meter reading is.
10 years 4 months ago #110009 by Paso Bob
McMopar, please email me at <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it. Thanks
10 years 4 months ago #110014 by Old Magnet
That high a s/n would have the swing gate that prevents catching two gears when shifting.
10 years 4 months ago #110017 by mrsmackpaul
Well I would have thought with the pedals worn like they are it has done a lot of work having said that I would be more concerned with all the work it has done if it hadnt been painted or have new tracks sprockets ect or new nuts on gear quadrant ! To me it tells me someone has looked after and worked on as it should be and someone thought it shouldnt have exposed bare metal and gave it a coat of paint all sounds like someone has looked after it but I could be wrong ?
Paul
10 years 4 months ago #110022 by drujinin
Replied by drujinin on topic Runs fine on Flat ground!
In the latest photo's, seems to be a lot of clearance in the lift arm pivot assemblies, sprockets are definitely rounded, look at 2 links, you can see a lot clearance.
I noticed the brake pedals the other day, but going back today, I thought it was odd that the clutch lever grease fittings appear to have paint over the ends like they never been greased.
Seen as it needs a Main Clutch, I would agree with the majority, its not worth $7000, maybe half that amount?
10 years 4 months ago #110028 by old-iron-habit
The picture is a little fuzzy but in the sprocket picture it appears that the sprocket teeth have been welded up and reshaped. I can not see any weld where a new sprocket ring would have been welded on. Two teeth are rounded like fairly new and the third at the bottom of the picture is pointed. I think that for $7,000.00 if you post a wanted add here on the Board in the For Sale section you will have some better machines to compare to or to chose from.
Time to create page: 0.341 seconds
