933 Engine Help
17 years 3 months ago #10336 by 933scotty
933 Engine Help was created by 933scotty
Okay boys I need help!!!!! I have a 933 42a978 with motor issues I found a cat D311-H (new style motor) power unit very low hrs. It has same block casting nos but has wrong govener,oil pan,front cover,crankshaft pulley, and bell housing. The head is the same also but the motor rating tag says 1500rpm and 46 hp (which I think is low) can I use the long block assy with my govener and pump assy ,covers and pulley in my tractor?? It looks possible but before I commit it would be nice to know. Thanks in advance!! Scotty
17 years 3 months ago #10337 by SJ
Replied by SJ on topic Engine
I can see no reason why you can,t but you,ll need all the changes to fit up to the tractor.
17 years 3 months ago #10339 by 933scotty
Replied by 933scotty on topic 933
That,s the way I see it just wanted to hear from anyone who new a little more than me Thanks alot. Scotty
17 years 3 months ago #10342 by AJ.
Replied by AJ. on topic Check
When you take the pan off check the oil pump pickup as I do not think that a stationary engines has two and two pickups are needed in the 933 for when going up steep slopes etc.
AJ
17 years 3 months ago #10355 by SJ
Replied by SJ on topic Oil Pump
Yes if the pump is removed you have to time the balancer shafts first before installing the pump. If the engine is on #1 the two shafts should have their flats straight up & there ia a threaded bolt hole in the bottom of the block to make sure they are correct if I remember correctly then you can put the pump up in place. There is timing marks on the pump gear but if the shafts are timed just put the pump up.
17 years 3 months ago #10356 by ccjersey
Replied by ccjersey on topic 933 Engine Help
It was specified for a loader probably, but I have just reassembled a D320 industrial that had a small scavenge pump and pickup running to the clutch end of the engine, the main sump is at the timing cover end where the pump drives off the balancing shaft drive train. It came out of another brand of large forklift.
If you have one with the flat plate type pan/cover with a sump bolted to that on one end, be careful when you remove it. Remove the sump first and reach up inside and disconnect the plate from the scavenge pump pickup tube before you remove it so you don't break the elbow that bolts to the pump.
17 years 3 months ago #10358 by 933scotty
Replied by 933scotty on topic 933 engine
The pan looks the same as loader but the drain plugs are on the side not on the bottom like the loader the motor looks almost identical except for what I have noted I dont know about the hp rating ( I think the loader is 65 and the pu is 45 ) is this changed in the pump itself? Thanks Scotty
17 years 3 months ago #10359 by SJ
Replied by SJ on topic 933 Power
Yes the power settings are done in the gov. with settings to the rack & RPMs & could be a different gov. spring but I don,t have parts books on them to check that out.If the original gov & inj. housing is used from the loader then things will be back to standard for the loader. RPMs should be checked out & set to specs anyway if you use the original 933 housing & gov.so it,s up to power & specs.after it,s up & running again.
17 years 3 months ago #10360 by 933scotty
Thats what Im hoping for Thanks again Scotty
Time to create page: 0.168 seconds
