Pony electric start
Pony electric start
10 years 7 months ago #107089
by lil cat mec
i saw this at a farm about 80mi from my place, we were picking up a military dodge power wagon
here is another way to run an electric start pony
1935 CAT 22 2f4455W
CAT 951
Thank you received: 96
10 years 7 months ago #107096
by bernie
My D42T had similar set up. Got fed up charging battery so pulled the contraption shortly after getting my machine. I'll never forget the charge I got hearing that starting engine fire up after using the rope for the first time.
I've wondered before if the pull rope spins the flywheel faster than a small electric motor for that initial impulse to the MAG.
10 years 7 months ago #107100
by lil cat mec
for speed, it would all have to do with gearing, that was the first time i have ever seen such a thing, i was facinated by it lol
1935 CAT 22 2f4455W
CAT 951
Thank you received: 15
10 years 7 months ago #107107
by lil cat mec
it was a weapons carrier,
this is the only picture i have of it, he sold it to his grandfather, whom now has 3 or 4... he also has a Gas CAT 60 with a spare motor, he has yet to start, 3 pull graders, a no.11 motor grader, etc... just to sum it up im jealous
1935 CAT 22 2f4455W
CAT 951
10 years 7 months ago #107108
by ronm
I think my D2 has had something like that in the past-there's a battery tray on the fender & holes drilled right through the brass patent plate...
10 years 7 months ago #107111
by Kurt Kocher
We have used an electric motor to start the pony engine. For some reason the older we get we seem to tucker out sooner.
Thank you received: 343
10 years 7 months ago #107112
by Ray54
The one someone went to the most effort that I have seen was a RD6 where they had to make a pulley and hub to fit the shaft that you put the crank on and then the bracket to hold the starter on the radiator and then had starter button in the end of the pipe that was used to tighten the belt. We have had pictures of different variation of motors both gas and electric on the fender of D2 and D4 tractors here on this board over the years.And not being very good with carburetors or magnetos and having a pony that will sputter but will not take off and run I know why someone would build a makeshift starter.
10 years 7 months ago #107118
by bernie
www.acmoc.org/bb/showthread.php?7904-Pony-motor-starter
Above is the link to post. Pics have been dropped. There were a few good ones as I recall.
Pony electric start
